Thanks to some improper handling by the boatyard at our marina ( I believe the water ballast valve may have been opened too far during hauling) the disk that closes the water ballast intake port is now bent and not sealing properly because the pins are no longer in alignment. I could ask them to try to bend it back but was wondering if that would be ok as a solution or if this needs to fit very precisely in order for the boat to function safely. I am a new owner/ sailor and don't want to do more damage / the wrong thing. Thanks, Maureen
