Water Ballast Analysis (From another thread)
707
Macgregor 26S Lucama, NC
Druid, your conclusions are still faulty. There has been absolutely nothing to prove that water ballast works only for wide flat hulls, or that the righting moment decreases at heel angles greater than 45 degrees.
If your first FBD is of the ballast tank only, then it is incorrectly labeled. You have the weight of the ballast labeled Fg, and in your 2nd FBD, you labeled the weight of the entire boat and ballast as Fg. For clarity, lets relabel the ballast weight in the 1st FBD as Wb. You have labeled the opposing force as Fh, and said that is the bouyancy of the ballast. As you later pointed out, the purpose of a Free Body Diagram is to separate something and examine the forces acting on it. If we separate the ballast from the boat, there are only two external forces acting on it: 1) Weight (Wb) due to gravity, and 2) the supporting force (Fh) from the hull which contains the ballast. Therefore Fh = Wb. Note that the water surrounding the boat doesn’t act on the ballast- it acts on the hull. That is an important difference. Fb is the force of bouyancy on the hull, and is equal and opposite to the weight of the hull and everything on and in it, including the ballast. Fb = Fg, but neither is equal to Fh or Wb. Fh is a part of Fb, and Wb is a part of Fg. There is no moment of any kind in the first FBD because both forces act through the center of gravity of the ballast.
If the second FBD was viewed with the boat in a vertical position, there would be a zero righting moment because both Fb and Fg act along the same vertical line, and the moment arm is zero. In the arbitrary position shown, there is a righting moment, because there is a right angle distance between the lines of action of Fb and Fg because, as the boat heels, the center of bouyancy shifts to the right. This moment is equal to Fb x D as you show, but remember that Fb = Fg = the weight of the boat and everything in it, including the ballast- NOT JUST THE BOAT WEIGHT! All of this remains valid no matter what kind of hull form the boat has. If the boat is sitting vertically, Fb and Fg are both centered, so there is zero moment. Fg always acts through the center of gravity, which has a fixed position regardless of the orientation of the boat; as long as the boat and its attachments (including ballast) are symmetrical, the cg is on the centerline. The center of bouyancy, however, is dependent on the orientation of the boat (what part of the hull is in the water and supporting Fg) and will move away from the centerline in the direction of heel. How far it moves will depend on many factors, including the hull shape, angle of heel, and beam. It is true that, everything else being the same, the greater the beam, the more the center of bouyancy will be displaced, and the greater the moment arm will be. However, that does not support your conclusion that in order for water-ballast to work, the hull has to be wide and flat. By the way, one of the criticisms I’ve heard about Macs is that they are too narrow….
Your statement "Note also that when things get REALLY interesting (over 45 degrees), the moving-Fb-style righting moment begins to get LESS (not zero), while the more classical keel-based righting moment gets stonger." is also not proved. First, every sailboat, with or without water ballast, with or without a "classical" keel, will shift its center of bouyancy when heeling. Second, there is nothing magical about 45 degrees. Your 2nd FBD appears to be drawn at about 40 degrees of heel, and shows the center of bouyancy lower than the center of gravity. These positions were drawn arbitrarily. Without a lot of specific information (weights, hull dimensions, etc.) about a specific boat, you cannot say exactly where these points will be. All you can say is that the center of gravity is on the centerline of the boat, fairly low; and that the center of bouyancy, when the boat is vertical, is on the centerline at some point above the center of gravity (otherwise the boat would not sit vertically). We can say that the center of bouyancy is displaced horizontally when the boat heels; we cannot say how much, or if it also moves vertically. You can say that if the boat heels enough for the center of bouyancy and the center of gravity to be on the same horizontal line, then 1) that is the position where the greatest righting moment is produced (D is at its maximum), and 2) that any further heel will reduce D and therefore the righting moment. Again, without a lot of information about a specific boat, we cannot say at what angle of heel that will be. And again, these statements apply to all sailboats.
Free body diagrams can be very useful, but we have to be careful not to read more into them than is there. -Paul
Nov 25, 2009
3
MacGregor 26M Caseville, MI
Druid, I don't quite follow your logic either :). Most traditional sail boats have a maximum righting arm around 60º of heel (give or take). It doesn't get stronger after 60º - it get's weaker until it vanishes at about 120-130º of heel. My Mac-M may even do a bit better than that with it's high freeboard. The M's COB at 90º heel is a very long way from the VCG compared to a traditional vessel - due to the ultra-high topsides.
FWIW - I never said wide-flat hulls are a *requirement* to make water-ballast work - just that it's one of the things you can manipulate. My M's 15º of deadrise is more "flattish" than some, but well on par with many keel-boats. I do say the lightweight part is a requirement though. If you use a lighter material - like water - for ballast, and position it higher than a traditional keel, you need to lighten the overall vessel to put the VCG back where it should be.
Cheers,
~Bob
Jun 7, 2007
875
Pearson- 323- Mobile,Al
Druid you need to look at an older Mac. Mine was a 1988 26D ?? Anyway it had a deep hull. My old Helsen had a flatter hull. The Mac actually sailed pretty well with the daggerboard up. It easily did a little better than a beam reach without the board. Dray out your diagrams and you might find that an hourglass shape or a V works very well with water ballast. Doesn't everything on Earth have weight??? Isn't weight on earth mass accelerated by gravity???
druid
Apr 22, 2009
837
Ontario 32 Pender Harbour
Check out my second model (the cylindrical one). Water ballast depends on the Fb moving out when the boat heels. As the shape approaches a cylinder, there is less movement of Fb and therefore less effect of "just weight". For those shapes, you need a deep keel with something heavier than water. Weight is mg, but when it's counteracted by bouyancy, there's no net force.
My Mac 22 was definitely "older" ;) It was quite flat-bottomed: two good-sized waves would stop her altogether. But she still holds the "record" (for me!) for Vancouver to Silva Bay - she averaged over hull-speed (off the wind, of course!).
druid
Jun 7, 2007
875
Weren't the Mac 22's and Mac 25's equipped with Cast Iron keels?? The Mac 26 was the first model with water ballast. My Mac 26D was a very fast boat especially when the wind was light. It was unusual in that it had reef points and three head sails. Using a combination of headsails and reefing it sailed well in most conditions. I never sailed in the open ocean as I was concerned about surfing and broaching. The rudder IMHO was rather weak. We did surf a few times when there were a lot of whitecaps in lakes. In my experience water ballast works very well for a trailerable boat. But there is no debate from me that a long thin keel with a bulb or lead on the end works better for sailing. But after about 10 years of towing sailboats I would never buy a fixed keel boat for trailering. We trailered out Mac a lot and the lack of 1200#s of lead or iron made that much easier and more fuel efficent.
Sumner
Jan 31, 2009
5,254
Druid can we for a moment go back to your initial post:
......The analysis here: http://h260.com/water_ballast/water_ballast_index.html
bothers me cuz I can't find where it's wrong but I KNOW it's wrong. I think I may have at least some insight, but would appreciate more................druid
You state that you can't find were the analysis of why and how water ballast can and does work at the link you provided is wrong. But you "KNOW it's wrong" ???? Then you say you have "some insight" as to why it is wrong, "but would appreciate more" ??
I would read that to mean that you are looking for someone to support you and provide information as to why it doesn't work even though you can't provide it. In all of the pages of posts since then no one has provided that information for you, in fact just the opposite. Person after person has provided information to add to or support the information given at the link you provided. Is there a reason you just can't say 'Ok, I get it, thanks'?
.... As the shape approaches a cylinder, there is less movement of Fb and therefore less effect of "just weight". For those shapes, you need a deep keel with something heavier than water. Weight is mg, but when it's counteracted by buoyancy, there's no net force.....druid
I'm wondering why when I put 3 people in my canoe it is noticeably deeper in the water. Since the human body is 55%-75% water I guess only the non-water part of our bodies is effecting how deep the canoe is in the water?
I'm also confused about this...........
....My Mac 22 was definitely "older" ;) It was quite flat-bottomed: two good-sized waves would stop her altogether. But she still holds the "record" (for me!) for Vancouver to Silva Bay - she averaged over hull-speed (off the wind, of course!)......druid
A Mac 22 has a PHRF rating of 252 and according to your comment has been faster sailing over that course than your current boat, yet your current boat ......
......... (which is one reason my Crown 28 flies by Mac 26's under sail... ;) )........druid
.... flies by Mac 26's which have PHRF ratings of 213 for the 26D and 222 for the 26S? Now since the Crown is a 28 foot boat and the Mac is a 26 I would expect it to be faster, just like I would expect the Mac 26 to be faster than the 22 which the PHRF ratings seem to substantiate. I can't find a PHRF rating on the Crown 28. I found a PHRF of 282 for a Crown 26.
So how can your boat that isn't as fast as your old 22 fly by boats that are faster than a 22? I can offer one explanation and that is that someone inexperienced like me is at the helm of the Mac 26 ;).
As you always say 'yes this has been fun',
Sum
druid
Apr 22, 2009
837
OK, I was WRONG to say "wrong", and yes, I do "understand" it now, but not because people gave me anecdotal information on how great their boat sailed. My understanding came when 1) I realized for a wide, flat hull, Fb moves toward the outside as the boat heels, and 2) the bouyancy that offsets the weight of the water is included in Fb.
Having said that, I'll add that for SOME boats (notably ones with cylindrical-like cross-sections) the original analysis IS false, since Fb does NOT move outward. In fact, if you do not separate out keel weight and buoyancy, you'd see that both move AWAY from the heel angle, due to the keel moving in the opposite direction. This gives the result I posted earlier.
So the analysis is not UNIVERSALLY correct, and depends on hull shape.
Obviously, the "record" run was an anomoly: winds were just right, tide was with us, etc. If conditions were identical, the Crown may or may not have gone faster. But it CERTAINLY goes faster 99% of the time, especially to windward. Note my other comment "two waves in a row would stop it altogether", whereas the Crown barely notices waves. Even my Cal 25 was much faster than the 22, or even the 26, upwind, especially into waves. I remember the "test sail" on the Cal - upwind in 8-12 knots. I was AMAZED at how fast we made Pt Atkinson, which was usually a 1/2-day sail for the Mac 22.
I also cannot find "base PHRF", but it's essentially a Cal 29, which is around 180, depending on who's measuring it.
druid
druid
Apr 22, 2009
837
I think that Druid is a troll. The physics involved is not rocket science.
Although it's not "rocket science", it's a LOT more complex than you seem to realize. The crux of it is the movement of Fb, which involves distributed-force analysis.You just BELIEVE Fb moves like he says it does, cuz, well, it's on a website, it must be right, right? And anyway, you put water into a jug, it's more stable, right? so it MUST be right...
druid
Jun 7, 2007
875
Druid it works the same in a cylinder. A cylinder of a given weight displaces a constant volume. If a volume of water is attached to the inside of the cylinder it will exert a righting force as it moves away from the center of bouyancy It really does not matter if the cylinder is suspended in air or submerged under water. As the center of mass moves to one side it exerts a righting force as it trys to get lower. Obviously when it is at it's lowest point it only exerts a downward force.
Nov 25, 2009
3
Eeesh. I don't think Druid is a troll. If there hadn't been years of all-out-bashing before this thread, we'd probably have said, "hmmm - good question". There have been so many statements to effect of... "water-ballast just doesn't work because it *can't* work (bogus physics to follow)" ...that we all have a bit of a raw nerve.
Happy sailing,
~Bob
Nik
Mar 15, 2008
247
MacGregor 26D Valparaiso, Indiana
My Analaysis.... 5 points to ponder...
1: Do you like your boat?
2: Do you enjoy sailing your boat?
3: Do you wish you had a different boat?
4: Can you afford the boat you want to have, rather than the one you have?
5: Answer to all these questions... Be glad you have your boat and are alive and able to sail. Keep her within her design limits and let the wind take you where you wish to go.
Good winds and seas to us all,
May the mast stay up, the keel down and no water other than outside our boat.
Nik
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
correct me if i am incorrect .....
the water ballest in effect acts like the pendulem...always seeking bottom ei the lowest point of gravity......
regards
woody
Jun 7, 2007
875
Exactly Woodster the weight of the water acts just like any weight. It goes down until some force stops it from going further. On a boat this is bouyancy. The most stable situain is where the center of bouyancy is directly over the center of mass(weight).
Jun 16, 2004
203
Druid, there is much more to how fast a 26s boat goes than water ballast. On my boat I have put racing sails on her, changed the rudder, and added a traveler. Perhaps the water ballasted 26s/26d's you sailed past with such ease had old sails/no traveler? Maybe their rig was poorly tuned? Or were skippers that were just learning to sail? Maybe :eek: they were not focused on boat speed?
You state that you have sailed past many of them...well, I have sailed past many boats that are not water ballast, some longer than mine, most more expensive. You would have to WORK FOR EVERY SECOND to sail past me...and (though statistics would be in your favor due to boat length, phrf I read, etc.'s of your boat I don't know about) you may not be able to!
Is the phrf for stock boats with no mod.'s? If so how much would putting good sails with wind indicators, a better rudder, and a traveler change the phrf?
Sumner
Jan 31, 2009
5,254
Druid, there is much more to how fast a 26s boat goes than water ballast............You state that you have sailed past many of them...well, I have sailed past many boats that are not water ballast, some longer than mine, most more expensive. You would have to WORK FOR EVERY SECOND to sail past me...and (though statistics would be in your favor due to boat length, phrf I read, etc.'s of your boat I don't know about) you may not be able to!..........
Druid, sounds like there is a challenger :), and since his boat will go on a trailer he'll come to you :dance:.
My money is on the Mac,
Sum
Our Trips to Lake Powell, UT - Kootenay Lake, Canada - Priest Lake, ID
Our Mac Pages
Mac Links
