waste Deck plate installation
8
Hunter 26 L'Orignal Ontario
waste Deck plate installation H26
I plan to install a pump out for my Porta Potti. Any Rx about the waste plate and vent installation on my H26? Thanks
Pat
8
But where???
Thank you for your imput. The question is more about RX on where should I drill the holes for the output.
Pat
Dec 2, 1997
9,011
- - LIttle Rock
Side deck is the best place for the deck pumpout fitting...
That is, if there is one...'cuz a horizontal surface is best. So you'd want to run the pumpout hose straight up. Vent line should be right below the toe rail.
I realize that it's not gonna be a straightforward as it sounds...'Cuz you may need to cut into a bulkhead or expose the underside of the side deck. So I suggest you take a look at other boats who have MSD portapotties installed...or maybe get some advice from your local dealer boat yard. 'Cuz it's a lot easier to figure out how to do what you've seen than it is to follow written instructions here.
Jun 26, 2006
8
Once again thank you for your reply. That is the problem, there is no nearby horizontal surface on the H26. So before cutting through, I would like to know the possible options. Has anybody installed a pump out on there H26?
Thank you
Pat
