Side deck is the best place for the deck pumpout fitting...
That is, if there is one...'cuz a horizontal surface is best. So you'd want to run the pumpout hose straight up. Vent line should be right below the toe rail.
I realize that it's not gonna be a straightforward as it sounds...'Cuz you may need to cut into a bulkhead or expose the underside of the side deck. So I suggest you take a look at other boats who have MSD portapotties installed...or maybe get some advice from your local dealer boat yard. 'Cuz it's a lot easier to figure out how to do what you've seen than it is to follow written instructions here.
Once again thank you for your reply. That is the problem, there is no nearby horizontal surface on the H26. So before cutting through, I would like to know the possible options. Has anybody installed a pump out on there H26?
