450 W/D
We have a W/D on our H450 and use it regularly. Yes, it only does a small load, but then again you don't wear many cloths on a boat when cruising. The drying is slow so we hang them up outside to dry when we can. If you use it when on the hook, you better have a water maker. As far as a picture, you don't need one. It is installed in the double-door hanging locker on the starboard side just aft of the main head. When the doors are shut, you can't tell that it is there. If you can get the vented type (we have the unvented) do so because the unvented one uses quite a bit of water on the dry cycle and the vented is much faster drying. Over all, we would not want to be without the W/D.
