washer dryer install
5
Hunter Cutter perth amboy
Looking for ideas, suggestions, comments on installing a washer/dryer on a hunter 37 cherubini... Thanks Harry
Jun 2, 2004
5,802
Dimensions? Is it one of those all-in-one units? Gas, diesel, or electric? You could cut out the cabinetry in the aft cabin. Maybe give up the shower or the vanity. How about where the nav station is located? I don't think we have ever seen that question on the Cherubini forum.
May 31, 2007
779
Hunter 37 cutter Blind River
How about a big bucket of soapy water lashed down on the foredeck, lidded, then go sail upwind in some strong winds and big seas. Afterwards, rinse by hose at the dock then hang the laundry up on the lifelines - of someone else's boat when they are away.
Dec 2, 1999
15,184
The only place that I can imagine that it would fit would be in the head area where the sink is. I do not know that the aft quarter berth would be deep enough.
Now with this said, how are you going to power the entire operation. They are not very efficient.
Ed A
Sep 27, 2008
333
Hunter 37c Tampa
no i just cant, a rusty old leaking loud ass washer and dryer, Requireing 220 volts and lots of amps you cant get on a dock, OR walking up to a cute gal at the laundry and maybe get directions to a net pup while she does the duds. No contest.
Ed A
Sep 27, 2008
333
Hunter 37c Tampa
They make a little washer you tow behind the boat. work great. no info.
if you wear less clothes it wont be nearly as big a problem
Jan 29, 2010
5
The washer/dryer I am looking at is an all in one. I would use shore power to use it until I retire in 3.5 yrs. Then I am thinking maybe a generator after that... Being once I retire clean clothes won't be so important. :) I am almost wondering if I could install it in the V-berth under the bed? But I would have to cut the front of the locker. But I am wondering if this would cause undue stress somewhere else?
May 31, 2007
779
I think putting the washer-dryer in the V-berth will cause undue stress on all the H37C owners if you tell us about it.
Dec 2, 1999
15,184
These unit cost about $900-$1000. Think about the local laundry. They will wash and fold your clothes, pressing if necessary. Thinking about adding the humidity to your boat, the modiification, cost of the unit and maintenance etc. I think there are better ways without screwing up a perfectly good vessel.
The laundrymat is about $1.00 - 1.50 per load plus drying cost.
Johnb
Hunter 37-cutter Richmond CA
And will you, with a clear conscience, put all the soapy water into the marina.
Jan 29, 2010
5
Thank you all for you input... Although laundry is 2.79 to wash it would prob. be better to just do it off the boat untill I retire, and better for the environment... Thank you.
Jun 2, 2004
5,802
If you mean to cut out the bulkhead at the forward edge of the step then yes, that is structural and would cause "undue stress".
Ed A
Sep 27, 2008
333
Hunter 37c Tampa
These boats dont really have room for washers, There isnt enough good space to take what you really need anyway.
May 21, 2009
360
Hunter 30 Smithfield, VA
Regarding washing, really you could reasonably hand wash clothes and then air dry. No need for a machine.
