I would like to install a fresh water anchor washdown on my Hunter 310 by tapping in to the boats fresh water system. Our normal sailing habit is mostly day sailing and anchoring for lunch or dinner and returning to the dock after. As such we do not use a lot of fresh water and a couple of times each summer I end up draining and refilling the water tank to keep it fresh. Because of this I think we carry sufficient fresh water to supply the washdown. If this doesn’t work out I can always install a thru hull later.
I ran the plumbing earlier this summer and found that my current freshwater pump (shurFlo 3901-0216 3gpm) does not provide enough pressure for the washdown. My question, therefore, is there a single pump that would provide both the necessary washdown pressure and also be suitable to run our fresh water system. All the plumbing is new 1/2 inch pex.
Thanks for your suggestions
Tim
Tim
