As many of you know I have had my 1980 Hunter 33 for about 10 years now, running the 2QM15 Yanmar as an auxiliary. This last July I ran aground on sandy Three Rooker Island when Hurricane Bonnie took the water out of the intercoastal. I ran the engine trying to get off in very wind blown water. The boat was tipping back and forth. Finally gave up and called for a tow. After getting off, the engine immediately began to run extremely rough. As it was night I anchored and waited for the next day. In the morning while the engine started it was rough running and would not rev up at all. I was about 10 miles from home, so sailed there. Restarted the engine to get in the pass and into my slip. It started but rough running and no power. Made it in and shut it down. I spun and started the engine the next day before leaving for two months. When I returned the engine was frozen. When I took off the head the cylinders had sand in them. It appears the engine needs a complete rebuild to run again. Rather than do that I am buying a new engine.
When an experienced engine installer looked at the boat he said the exhaust set up was designed to fail, as there was no loop in the exhaust. To review, the exhaust ran immediately down from the manifold in an elbow to the muffler under the fuel tank, then directly out the thru hull a few inches from the waterline. He said that any healing of the boat brings water/sand directly into the engine. And that is certainly what happened during the windy grounding.
If your hunter has the same exhaust design as the 33, please consider redoing the exhaust as soon as you can to prevent the intrusion of water and sand into an old engine on a bad day.
