Ray Bowles
I have a 1995 Hunter 26 that, to the best of my knowledge, is still equiped with the factory installed "Rule 360GPM" bilge pump and the "Sure Ball Float" actuation device. After having read on this site about Rule bilge pump problems other owners had on different model Hunter boats I thought I should check mine. To say my blood ran cold and that I'm very mad is one of the nicest ways to convey this warning.I found all three factory 10 gauge wire connections that attached to the Rule pump/float were failed as they left the factory. The crimps were improper and the connector the wrong size for the pump wires. ALL THREE WIRES SEPARATED SIMPLY BY LIFTING THE PUMP OUT OF ITS MOUNT. This movement was no more that 6 inches, without stress, when the first wire failed. All three wires had bent back wire strands showing that they were not inserted into the connector properly at crimping time. The main wire harness from the control panel was still in its plastic flex protective housing and had talcum powder residue included.While there is not much possibility of this size pump doing much to control a serious water problem I damn sure expected it to be wired properly.What should I check next?RayS/V Speedy
