Just a friendly warning for anyone who has or is considering putting a VHF-AM/FM antenna combiner on their boat....BE CAREFUL!Shakespeare sells a unit designed to allow you to use your VHF antenna to be used as your AM/FM antenna source, and if your rigging/keel ground is separate from your boat's DC ground, this unit will allow a current path between the two. After discovering my brand new Flex-O-Fold prop was suffering from galvanic corrosion, with a zinc installed on the shaft, I found that this antenna combiner was providing a current path for stray DC from the marina water to enter from the keel and exit from the prop, causing galvanic action and eating my beloved Flex-O-Fold! See Don Casey's book "Sailboat Electrics Simplified", page 166-167, for the full explanation on this process. If you do not have a flexible, insulated coupling on your propshaft, any connection between your keel and DC system will eat your prop if any stray DC exists in the water!
