Want to build small sail boat for handicapped child need input
Feb 16, 2015
20
MacGregor Venture 222 Yeopium river, hertford Nc
Hello , thanks for any input . here is situation daughter parallelized waist down want to build 8-10ft dink, cat rig ? very stable cant go turtle , center board , don't want boom sweeping deck risk hitting her ,lateen rig? some curved seating side to stern to side so she can transfer around. also thought I would mount trolling motor in a well so she could lower it and get in out of pier. any plans out there ,or any experience you might have in small sailboats
Oct 26, 2008
6,241
Catalina 320 Barnegat, NJ
Maybe consider wheel steering with a sturdy pedestal to give her something solid to hold in the center of the cockpit. Also, she can shift across the stern seat without interference from a tiller. I admire and am inspired by the can-do spirit when young folks overcome obstacles!
May 12, 2004
1,505
Mark, Google "sailboats for handicapped children", if you haven't already. The links there might get you off to a good start. Good luck to both of you and a "high five" to your daughter. What an inspiration she must be to other children.
kito
Sep 13, 2012
2,011
I know you want to build her something but I think a small catamaran would be perfect. Stable, no boom and plenty space to move around.
edit: Ooops......you need a trolling motor. Never mind
Mar 23, 2009
139
Rafiki 35 North East, MD
I realize you're a bit farther south, but you may want to reach out to the folks at Chesapeake Region Accessible Boating ("CRAB") http://www.crabsailing.org/. They do amazing work to get folks of all abilities out on the water, and have come up with some pretty ingenious devices to make sailing possible for people with special needs. Also, their fleet is comprised of Freedom Independence 20 sloop-rigged boats that have built-in pivoting chairs that allow the chairs to be moved by the person sitting in them from one side of the boat to the other during a tack. I know you said you wanted to build a boat yourself, but looking at the design for these boats may give you some helpful ideas. There is more info about them on CRAB's website at http://www.crabsailing.org/content/fleet.
Apr 19, 2012
1,043
O'Day Daysailor 17 Nevis MN
A kayak with outriggers and a sail similar to a Hobie Adventure Island might be worth looking into. It's quite stable, doesn't require moving from side to side when you tack, and has no boom to worry about.
Johnb
Hunter 37-cutter Richmond CA
Great ideas above. I would think about starting with a Sunfish which could probably be acquired very inexpensively and then adapting it:
Reduce the sail area
Figure out if it would be feasible to weight the centerboard - use a multi purchase block system to raise it
Add flotation to the mast (plus lock it in)
Add handles and supports
Adapt the tiller to make it extendable and easy to reach.
Raise the boom a bit
You have not specified the size, weight, strength or age of your daughter and that would make a big difference.
I had polio as an infant and have useable but weak legs. I am however OK on upper body strength and have been able to canoe/kayak/sail. This has given me access to the outdoors and huge recreational opportunities.
I hope it turns out well.
Feb 16, 2015
20
thanks all good help will look into the sights mentioned she is an adult upper body strength week to average I was thinking a trimaran with cockpit with all lines running into it i am in the middle of re working my v222 i am starting this in planning stage for winter when not sailing i also built a davit with electric wench to get her in a out of river or boats work well.
May 24, 2004
7,164
CC 30 South Florida
It is the smaller boats that require the most effort to sail. Small boats have no ballast other than the shifting weight of the sailor. Pardon my ignorance about a handicapped person sailing alone but have not owned a boat that at one point or another did not run into a situation requiring quick action.
Nov 18, 2013
171
Catalina 310 Campbell River
The Canadian designed and built Martin 16 is a boat that allows children and adults with physical disabilities the possibility of leaving their wheelchair or other mobility device and going sailing! Even individuals with weak arms or no use of their arms can sail independently using power assist technology.
Jul 25, 2016
3
TPI Expo Expo Solar Sailer Portsmouth, VA
As a former physical rehab nurse, I do have a couple of thoughts and maybe concerns. I would ask how well she does sailing on your boat. Can she control her body and maintain her position? In a wheelchair, her lower torso is pretty much locked into the seat of the chair, so it moves with her as if it were part of her body. On a bench seat in a boat, she can slide sideways and may also move front to back. That wont help her in remaining upright and in control of her position while she also had to tend the rudder and the sails. You mention that you built a lift to get her in and out of the boat, that's a big plus. How well does she manage with her own transfers?
My other thought would go to how she would handle herself if she did hit the water. I'm sure she would have her PFD on and even if unconscious, that should keep her face out of the water. But how well does she swim, with or without flotation?
Your original description sounds like one of the melonseed cats, very wide and stable and just one sail to manage. Another boat might be a mudhen. You could put a larger sized trolling motor on it for getting underway. A seat that somehow swivels or moves side to side would help her with control, I would just make sure that it is easy enough for her to get out of it in an emergency.
-na -NA Anywhere USA
Matt gave you a good source, CRAB, to start your reseach. Many years ago when working with the disabled, I first worked with an organization called Shake a Leg. Not sure if they are still around but gave me a lot of help in designing or outfitting a 26 footer for a 60 yr. old. paralyzed on the left side from a stroke. They sure were extremely helpful which worked out well for my customer.
There are plans for a small Catamaran, maybe 10', in which someone wouldn't have to move around the cockpit. The original design has foot pedal steering but that could be modified easily to whatever works. I believe it was shown with a sunfish sail. Almost no risk of capsize at any wind speed that would be reasonable. I need to look around for the plans for that design.
I think this is it. Bananas. We were thinking of building a fleet of them to bomb around our harbor in the off season.
http://www.searunner.com/index.php/...nt-camber-trimarans/11-our-designs/seaclipper
Feb 16, 2015
20
thanks again all , {Shemanrd} yes the seaclipper 10 by searunner is the one I had in mind thanks for giving me the web sight .I saw it small boat or wooden boat magazines . looked through the pile to see if I kept it must have passed in on to someone . I think, If I remember the article they were in the NW Seattle area, any one have any experience on them thanks Mark
May 12, 2004
1,505
Have you looked at WindRider? We had one in our rental fleet a while back. It's a small trimaran. You sit in the middle hull, with all the controls right there. A very stable craft. The only downside for your application is that you control the rudder with your feet. However, I'm sure there must be a way to convert that feature. Here is their site. Good luck.
http://www.windrider.com/windrider-sailboat.html
