I seem to recall that you (MS) gave a favorable review to Walmart batteries.  I recently noticed that my (Sears) GRP 27 deep cycle batt was failing to charge and the other batt in my single bank was a GRP 29 bought at a different time.  So, I basically decided to start new all the way around.  I purchased 2 EverStart GRP 27 DC for house bank and 1 EverStart H5 for start batt and finished with the installation.
As an aside, one reason I was attracted to the Walmart DC batts is the vertical height to top of post is about 1/2" lower than competing brands, which is very important in my batt compartment (taller batteries just won't fit without modifying the compartment).
Being the kind of "shoot first, ask questions later" kind of guy that I am
, I'm looking for some helpful input.  First off, I'm frustrated by lack of info that I can find on internet.  When I could find information on the ah rating, if I can find anything, it comes in a variety of formats, i.e. hours rated at 5 amp, 15 amp, 20 amp, 25 amp.  None of them seem to translate into an equalized value so it seems impossible to compare.  In any case, at the store, the battery claims to be rated at 109 ah.  This seemed too high based on values I was able to gleen elsewhere on internet.  Can this be right?  Obviously, the lack of clarity didn't deter me from laying out the cash ...
Secondly, the start battery is described as "automotive" opposed to "lead-acid automotive" for the ones that have caps for re-fill. Obviously it is maintenance free because there are no caps but, what does this mean? Is it a maintenance free lead-acid, gel, agm? No literature describes.
Ok, I didn't think there is a need to worry about that ... I have a Blue Seas ACR linked to my Dual Circuit Plus switch (I'm sure ya'll have heard enough of my advocacy for that
), so I figured the lead-acid DC batts in house bank matched with the automotive start batt on aux bank would still be compatible.
My only means of charging is via the 80 amp alternator on my new 2YM15 engine. I'm not connected to shore power and haven't installed solar charging (good idea, I know). I want to sync my Xantrex Linkpro monitor to the fully charged batts. I brought them home and charged with a (somewhat) cheap (new) charger that I bought. I charged to float, surprised that it took about an hour for one of the batts (sales guy said they should be fully charged as the stickers were from May). I've put them in the boat and had lights on minimally, and possibly ran the engine for 30-45 minutes. I want to make sure they are fully charged when I sync. When I checked the amperage with a gauge, I get 12.4 on one DC, 12.5 on the other (that was before they were combined - now they are combined at about 12.5 after cooling down off the alternator) and IIRC about 12.6 on the start batt. Is this normal? The numbers on the gauge are always within a few hundredths of the monitor. When the engine runs, I saw 14.2 / 14.3 on the monitor and the charging amps seem to be about 4.1 amps with rpm at about 2000 - 2400.
Should I bring the charger to the boat and run them up again (I might have to remove the batts to do that as I'm sure that running an extension down the dock will be frowned upon)? Can I rely on the boat alternator to keep them topped off at this time? Should I set the capacity at 218 ah or use the default setting (200 ah)? Should I leave the default charger float setting on the linkpro at 13.2?
All responses, good, bad, ridicule, are welcome ... I have thick skin and the capacity to recover from just about any poor decision that I have made in this regard!
  Thanks all!
