Wall-liner material
Mark Crociati
Anyone know of a supplier that sells the wall-lining (decorative material)on my Hunter 1976? I was told Hunter sells it. I called them and they claim they do not. Has anyone use regular head-liner material used in autos? Response appreciated. M.C.
Dec 4, 2003
12
- - Bahia Beach, FL
Try this link.....
Go to this link. Click on "Products", then "Marine Hulliner". This place is in Tampa, FL, but I'm pretty sure that you can order from him, if you like.
Tammy
I have a less expensive solution
YOu can use indoor/outdoor carpeting, it costs a LOT less than any hull liner. My husband & I are in the process or refitting our 1979 Hunter 30 and we are going to use indoor/outdoor carpeting. I've already been to the flooring store and the cost could be as low as .57 cents a yard (width is 12 feet). I've done a lot of reading and it seems that many owners have replaced the ugly brown hull liner with carpet. I believe that Don Casey has said that carpet is an acceptable replacement material. So, you can spend 14.99 & up per yard for Marine Hull Liner or you can spend around $1.00.
Mark Crociati
Indoor/Outdoor capeting
Thank you for the advice, can you tell me how you fasten the carpet to the hull? Can I use a spray glue? Your response is greatly appreciated. M.C.
Tammy
Hull Liner
I believe that you can use any carpet adhesive that is safe for fiberglass. My husband has been looking at carpet adhesives in the hardware store & severl brands say that they are safe for fiberglass. Do you own Don Casey's "This old Boat"? I highly recommend it, if only for the fact that he says that you don't have to go to a marine supply store to buy products for your boat.
Mike
I bought mine last year from Hunter.
I bought mine from Hunter last year. It was reasonable and I'm very satisfied with the quality and look.
Mark Crociati
I tried that!
Hunter they don't supply that sort of thing, do you mind me asking who you spoke with and what tel. you called. Any input is appreciated. M.C.
Feb 15, 2004
735
Hunter 37.5 Balt/Annapolis/New Bern
they did..
few years back, you could buy it buy the ft. Try Mike Thomas (he used to be the parts guy.)
