Nice upgrade
I really like the Jabsco Sensor Max 14 that I installed this past winter. But take note of the water pressure rating if you like high water pressure. Ours is rated around 30 psi. I say around, because the published ratings are not consistent. I’m fine with the pressure on ours, even though it is less than the unit it replaced. I think the lower pressure is easier on our limited water supply. There are a number of units rated up to 80 psi, but I thought that might be excessive for our plumbing.The lack of pulsing is worth the switch. And it is pretty quiet though not silent.
