I am installing a new 55 HP Volvo 130S sail drive in my boat. Engine cooling water goes through dinky water inlet holes in the drive leg. Other owners report eels and other marine life getting stuck in the tiny drive leg water inlet.
I would like to bypass the drive leg water inlet and install a separate cooling water inlet in the bottom of the boat, using a thru-hull, seacock, and water filter like on a conventional marine diesel inboard engine installation.
Any problems with this approach? Does the drive leg water inlet have a secondary function, like cooling drive gearing, that would be eliminated with this approach? With the external water inlet should I plug the little drive leg ports? If so how? Warranty issues using this approach?
Anyone with Volvo drive experience with suggestions would be appreciated.
