mine too
I better put a "smoking prohibited" placard on my boat! I've got the MD22L 50 hp volvo also, and it smokes like crazy till it warms up, when it still blows a little smoke but not enough to be an embarasment at that point. I've heard all sorts of explanations from my mechanic and from Volvo, such as, "it leaves a bit more oil on the cylinder walls when it shuts down", and probably more accurately, that the valve guide seals are more prone to dry out when it is not used all the time. The suggested cure: "Go out and run the hell out of it for 10 hours." Hey, it's a SAILboat, right. Also have leaky radiator caps, (replaced at AutoZone a couple of times) but so far the water pump is OK. Anyway, it runs perfectly otherwise, so if the smoke problem is not terminal, I'm happy with it.
