Check connections, verify results
Generically speaking, all these suggestions have merit. Generally, meters draw a minuscule of power from the circuits being measured. Like the current draw of modern instruments would be less than a few milliamps at worst. Digital meters in the microamp region, some much less.(milli = 1/1000 , micro = 1/1000000 ).In addition to these suggestions, keep in mind that analog meters "work" in a similar manner to a dc motor, in that the current developed in the instrument can be affected by other electric fields in their midst. That two meters by the same company has the same error, I would suggest verifying the accuracy of the meter at three points: Near zero, mid range, and max range. If it is consistently off by .3 v, then check for an adjusting screw in the center of the meter face. If an digital meter, the dc interference doesn't ring true, but could still have an adjusting screw. Also check the face and look for a specification, may look like x ohms / per volt. As already mentioned, you could have a multiple break in the wire. Some methods of connecting wires tend to "damage" the strands. It is possible, though not statistically likely, to have a few broken strands of wire if it is crimped. Try "paralleling" each wire to its source with a wire jumper using alligator or crocodile jaws. If the meter changes, then replace or recrimp the wires.If you check the meter, and find the differences between low, mid, and high to be different amounts, I'd then check for 2 (two) adjusting screws, but normally these should be factory preset. I'd then call the manufacturer or dealer of the meter.when checking the "specs" on a DVM or digital volt meter, be very careful not to confuse the "number of digits to the right of the decimal point with accuracy". The two are implied as being related, but not necessarily. Often times the basic accuracy may be stated as "accurate to within 1/1000 or 1 Micro Volt*", and the star goes to the fine print of "*when used on the 0.1 range". Not much good on the 50 volt range.(Sorry this is so long. It may be more than you need.). If more is needed, you can email me through the HOW member forum. Bob
