Voltage drop at panel
Jun 6, 2006
6,990
Two important concepts that have not been addressed are voltage drop is due to current flow and resistance can sometimes be due to the heat that current flow caused when flowing through a high resistance spot. You cannot measure voltage drop with an open circuit or the circuit turned off. Open and off circuits ALWAYS show battery voltage. There has to be current flowing and the more current the larger the drop. That current can heat up the corroded connection and raise its resistance even higher.... maddening finding these as they "look" ok and test out as low resistance and even work ok for a while till the connector gets hot from current flowing through it.
The best way to find where the volts are turning to heat is with the circuit on (yes a challenge on a starter circuit but don't think we have that here) and probing on both sides of the suspect connector. That is why the probes are pointed, so you can pierce the insulation with just a tiny hole while the circuit is in operation. set your volt meter to less than 2 volts range.
On hunter starting circuits there are something like 11 connectors between the batter + and -. Now if each only contributes 0.33 volts drop; 11*0.33=3.63, 12.6-3.63=8.37 volts available across the starter solenoid. I know for a fact that they take at least 9.5 to operate the solenoid and 0.33 volts drop in a connector is not horrible. Just when you add them all together they make a difference. so you might want to consider the possibility that it is not just one high resistance spot but many "slightly" high resistance spots.
NYSail
Jan 6, 2006
3,155
Beneteau 423 Mt. Sinai, NY
One point to this problem is that this is a recent event...... Am I correct? That would lead to finding the recent cause or failure.
May 13, 2011
420
Hunter 40.5 Legend Jupiter
Brian - thanks for the subtle reminder :) I need them
Bill - been chasing cables but yet to get to that starter - cleaned the ones on the transmission. Figured I would clean pretty much everyone at this point
We are scheduled to move to marsh harbor in a day or two.
Going to sit in a marina for a few days to resupply, clean the boat up, do laundry and most importantly fault find this
Will let you know how I get on - thanks again to all for passing their knowledge / suggestions.
Hopefully we will find the issue with this and our non charging alternator that shows 14v out the back of it
420
NYSail
Shamefully I have to say this is something that seems to have been the case since I bought it but I was either too lazy, too busy wth another project or just lacked the understanding that my batteries shouldn't be drawing down that fast
You pick :)
