Hi all,
I have a question around voltage readings. I have a Freedom 20 charger / inverter that is controlled by a Link 1000 on my 2006 Beneteau 473. I generally use the Link 1000 to read the voltage on my house and reserve banks. The reading are consistent and I understand where the voltage is being read from. Use the Link for Amps, AmpHrs etc. This seems to work fine for me.
My question is around the analog and other voltage readings. I have 4 or 5 places on the boat that will actually give me a voltage reading. There is an analog meter on my DC panel, several of my insturments have a voltage reading and even my tank level meter has a voltage reading. They all seem to be from the same source reading and they are all lower than the Link 1000. Sometimes significantly. I've even had occasions when the Link had me at 12.3 or 12.4 Volts and the other readings were below 11.0 volts. The batteries seem to perform in line with the Link readings so I have not thought to much about it. But I was curious as to why this difference might occur. I'm not really sure where the anolog reading taps in to get the voltage.
Any thoughts here?
Glenn
Any thoughts here?
Glenn
