Volt-Ohm Meters
John
Can any one suggest a volt-ohm meter to purchase for use on my 1987 37' Ledgend?
Bob Schmit
Great Question
I think what type of volt/ohm meter you use would depend on your skills. An under $10 meter with a needle style face versus digital can do most tests you need on a boat. Especially if all you want to know is a go or no go situation-is there voltage or no voltage (on the volt scale) or is there continuity or no continuity (on ohm scale). As your skills at trouble shooting and diagnosis improve, a more sophisticated digital meter would be better. The important thing to remember using a test meter is what readings should you expect and if you don't get that then where do you need to check next. What I'm getting at, I guess, is it's not so much the quality of the test meter as the knowledge of the person using it. Sometimes the best thing that comes with these meters is the instruction pamphlet on how to use them. Just my opinion, gained after 21years as an appliance repair tech.
G
Greg Stebbins
Cheep and simple times 2
I recommend a simple meter from Radio Shack. Something under $30.00 would be fine. I'd then buy a second as a back-up and store, battery out. Now you're covered!
C
Colin Campbell
Meter is a must!
It isn't critiacl which meter you use, you have the important part right in having a meter on board. I try to never leave dock without one.
SteveC
I prefer a digital one(inexpensive) but I
agree with Bob in that you should have a fair idea of how to use it when it comes to diagnosing and solving electrical problems...
E
Ed Schenck
Just did it.
Had one that went belly up. Went to Loew's and paid $16. and made sure it had Amps and at least four Ohms scales. Then spliced in my old leads because I wanted longer leads AND alligator clips. Trying to find a good ground while measuring something on a boat can require three or more hands.
terry dornan
Buy the Fluke
Model # 87 is a good coice- frequency counter is a nice plus for calibration of wind and speed instruments.
