So, since I have had my Vision 32. The floor in front of the toilet was springy. I pulled off the brown floor mat and discovered a panel underneath Was this standard for Hunter? The reason I ask is when I unscrewed the floor I found the support brace was soaked from a pin point leak. Apparently the screw went through the hull a tiny bit to allow a slow drip.
