Vision 32 deck joint
coxjam
Sep 7, 2009
68
Hunter Vision-32 Texas Gulf Coast
can somebody supply a drawing of the Visions deck joint, and how to go about sealing it? I believe this boat has a leak all along the starboard side from amidship aft. thanks.
Rick D
Jun 14, 2008
7,187
Really? Are you sure that's the source? There isn't a lot of torque on this joint owing to the free-standing mast. I'd be really surprised. Have you pressurized the interior to trace the leaks? If not, that should be your very first step. As to the joint configuration, better you check with Hunter. As far as chasing a leak via pressurization, see the search routine and if you can't find it, re-post here. Good luck!
coxjam
Sep 7, 2009
68
No I'm not sure but that is what the surveyor thought because of the extensive rainwater damage. Rainwater is also coming down the mast thru the deck into the compartment where the base is, aft port quarter into aft cabin, and thru the companionway doors which has rotted out the walls in the head as well as supporting wood frame of companionway.
