Vision 32 Cast Iron Keel Prep
39
Catalina 22 Deltaville
OK Guys, I need some help here.
Can someone help me determine how I need to prep my cast iron keel for bottom ablative paint? I attached a few pictures that may indicate some corrosion I am concerned with. I was thinking to use a side grinder with a wire brush wheel to clean the "corrosion spots". I want to know what to use on the bare metal to seal and treat the area before painting.
I also need help to determine how to repair a couple small blisters on the fiberglass rudder.
Thanks for your comments and help.
Bobby
470
Hunter 33.5 Portsmouth, RI
I have an iron keel on my 1990 H-33.5 and have addressed the same problem that you have. When any of this appears, I wire brush it (your wire wheel on an angle grinder is a better approach), then I coate all of those areas with Pettit Rust-Lok.. Then I have used epoxy to "fair" the keel, before applying anti-fouling paint (Pettit Trinadad SR) Each year there have been less and less areas to prep. Removing all paint down to bare keel, then applying Pettit Rust-Lok to the whole keel would have been a better approach for me.
Rick D
Jun 14, 2008
7,187
I Feel A Bit Stupid!
I had a Vision 32 for nine years and always thought it was a lead keel!
Oct 30, 2011
542
klidescope 30t norfolk
rusty keel
Yea I spot patched my cast iron keel grind ed spots and feathered edges at exist barrier coat then applied interlux interprotect 2000e 2 coats then hosed down with water waited a week till missed spots - joints re appeared grind ed and repeat till no rust then applied bottom paint went in water last week gonna dive on her when water gets warmer and see if any more rust some spots had to really dig into keel till got to hard metal then sealed and built up with glass till flat again.
Dec 3, 2003
544
None None Rochester, NY
I am told to do the job right, you should have the keel sand-blasted down to bare metal, then immediately apply epoxy coating. I wonder how much it cost to have that done.
