Vision 32 AC/DC panel re-work
Aug 21, 2019
41
Hunter Vision 32 Shilshole Bay Marina
A series of POs have left the wiring on both the AC and DC sides of my distribution panel a bit a mess to say the least; not the worst I've ever seen, but a proper rat's nest nonetheless. I have looked into replacing the panel with a pretty Blue Sea Systems rig, but the dimensions of their available products don't quite work with the space I have available. Instead, I would like to tear everything out of the factory metal panel and start from scratch. There are precious few markings on the circuit breakers presently installed, and I want to make sure I'm sizing them correctly. Has anyone done a job like this? Is there a way to test the breaker itself for its rating, or do I have to undertake the unenviable task of tracking down the draw from each load on each of the circuit branches?
The breakers in the panel are sized for the wires from the panel, not the load. Most panels have standard breaker sizes anyway. Find the OEM manual for your boat that should show each of the circuits originally installed and that should tell you the purpose and size of each of the OEM breakers. Only YOU know what you have on you boat now, so a lot of detective work is required. You can do it. Even without buying a new panel, since a new panel is going to do nothing about helping you in what's happening downstream.
May 27, 2004
2,059
Are you saying that there is no "number" on each of the circuit breakers in your current panel?
All of my original breakers, though from 1979, had the amperage number on the breaker.
If not, you'll need to assess the amperage load and wire size on each circuit.
That is a job for an electrician.
May 20, 2016
3,015
If the values have worn off the toggle, you can always look at the side of the breaker, the text there should be intact.
Likes: Ward H
Les knows his stuff.
Created a great upgrade to my boat.
Replacing the wire nest on my boat.
It is a project still in the last phase of completion. Big task. Just takes some skill, some guess work and a lot of perseverance.
Likes: Ward H
