K
Ken Juul
Following your suggestions on keeping the smells clean from the head I have rearranged the inlet hose to allow flushing with ships water prior to leaving the boat unattended for a long period. I have also started adding 1/4 to 1/2 cup of vinegar to that final fresh water flush. We had guests on board for a long weekend. When I did a hurried cleansing flush leaving the boat I noticed nothing wrong. Came back to the boat a couple weeks later and the toilet is now much harder to empty. Feels as if there is a restriction between the head and the holding tank. I didn't measure the vinegar, could a overdose hurt the pump seals or joker valve causing this restriction? Or should I start looking for restrictions in the lines. Also the tank was pumped upon return from the long weekend so that removes the possibility that it is full. Thanks for the help. Luna Loca C34 #1090
