Victron BMV 600 Alarm
35
RV RV home
I just installed my Victron and it is works good.
My question is, do I have to attach an alarm or is one built into the unit?
Thanks, Rex
Gary_H
Nov 5, 2007
469
Cal 2-25 Carolina Beach NC
I haven't actually tested it but the manual seems to indicate that there is an internal buzzer used with the various alarms. Such as state of charge that drops below a preset level.
"A BUZ:
When set, the buzzer will sound on an alarm. After a button is
pressed the buzzer will stop sounding. When not enable the buzzer
will not sound on an alarm condition."​
Feb 6, 1998
11,760
Thanks, Rex
You don't need to do anything with the alarm if you don't want to. Every setting is fully programmable and there is a relay inside the unit that can be used for keying another external device, relay etc...
The manual for programming is a tough read but it's a must do otherwise you'll never get it to work properly..
