Friends,
I've recently installed a Victron Battery Monitor in my Catalina 30 and it's working well but it is failing to keep any data on:
1. Depth of Last Discharge
2. Depth of Average Discharge
3. Number of Charge Cycles
After much effort and finally just a blast mail to every salesman listed worldwide on the Victron site I finally got a response telling me that it would seem that the Monitor is not recognizing a fully charged state and to check a few settings. I check those settings (tail current, charge detection time and charge voltage) and all seems well there.
The documentation says that it will automatically sync itself when the batteries reach a fully charged state and it does report that it has sync'd itself four times since I've installed it.
I'm wondering if I need to manually sync it, or perhaps remove power from it altogether and sort of "re-boot" it, if that makes any sense.
BTW, the Peukert Exponent for Sam's Club 6 volt lead acid golf cart batteries made by Interstate is 1.07 and inputting that info to the monitor made it much more accurate in the state of charge field.
Thanks! Dan.
Thanks! Dan.
