I have had my Victron 600s for a couple years in my motor and it has worked fine. Today I moved it to my new motorhome.
I ran into a perplexing problem when I put in my battery monitor tonight.
I have double checked all connections.
Everything seems to be working correctly. The monitor shows amps in and out. But voltage reads -.02 volts. I checked voltage on the battery and it show proper voltage.
I tried 2 different monitors with the same results.
Any ideas would be helpful - thanks.
