I
Ivan Edwards
I would like to solve a vibration problem when under power at greater than 2500 RPM.Seems to come and go with the swaying of the boat from side to side... Had alignment, shaft checked for straightness,new cutlass bearing, prop cleaned...I'm guessing that there is enough softness in the engine monts that the engine is swaying and causing mis-aignment. Do I replace the motor mounts?Should I try one of these break-away isolators,or a CV joint, between the prop shaft and the transmission?Have the prop/shaft re-balanced/straightened?Other ideas?Ivan Edwards
