Steve
I knew my cutlass bearing was bad so when I pulled the boat to do the bottom I planned on having it replaced. The yard showed me that my prop shaft was slightly bent just aft of the strut...so I replaced the shaft as well. They sent the prop in to be reworked. Now back in the water and my vibration problem is worse! They just finished aligning the shaft and now are telling me that my prop must be replaced. I suspect that they used the new prop shaft as a pry bar when removing the cap (where the emergency tiller handle fits) at the top of the rudder shaft (rudder had to be removed to install new prop shaft). Any ideas? If I do go ahead and order a new prop they are suggesting I get a 3-blade instead of the 2-blade? My Catalina 36 has a 21hp Universal diesel with 2:1 transmission. Appreciate any thoughts.
