Newbie. 82 Hunter, Yanmar 8hp diesel. Seems like excessive vibration when running.
Reason for this post: looking for advice on how to isolate the source of the vibration and fix.
The cutlass bearing has some slight play when grabbing the shaft. Now that boat is out of water, I want to check this play against other boats.
Besides the cutlass bearing, what else could be causing the vibration ?
Do props every need re-balancing ?
I assume engine mount alignment is a possibility ? I've not measured runout, but the coupling beween the driveshaft and transmission seems true.
The stuffing box does provide any support, right ? It is a just a flexible seal joint, and does not provide shaft support or alignment ?
Thanks for any input !
