Vibration after tranny oil change - what the heck???
754
Oday 28 Madison, CT
Located some Dexron II on the web and should have by the weekend. Will see what that does. have my doubts, but one never knows. The slipping before, not now, theory seems plausible also.
Aug 16, 2006
281
Ericson 32 Oregon coast
The previous owner might have put 30 weight motor
oil or gear oil in there by mistake . I had a boat once that specified 30 weight non detergent oil in the transmission. Gear oil will have a sulfer smell to it. Transmission fluid is made from a very light viscosity oil. If the vibration and noise is slightly more than before it could be the normal sound without the dampening effect of the heavier oil.
Jul 5, 2011
754
Oday 28 Madison, CT
Thanks, but know the yard mechanic that served the previous owner and he specialized in this powerplants, so that is not likely. What I took out was also thinner than motor oil.
Jul 5, 2011
754
Oday 28 Madison, CT
Well the weather and a trip out of town killed my best intentions on getting back to you all on this. Took the boat out yesterday, first true run using the Dexron II. All smooth again and I think honestly smoother than it ever was. Maybe it was the use if the DII, maybe as a German friend suggested, I got some bubbles in the new fluid installing, but whatever it was I have a great ending and am very appreciative of all of you than weighed in. Now I am going to replace the fresh water pressure pump I burned out this afternoon! And that I know how to do.
