I am the second owner of this Boat with 1985 Universal M12 and Hurth HBW 50 tranmission. 600 engine hours perhaps, but was not sure when trans oil was changed so did the job this past week myself. It's a bear to get to the drain plug so I pumped from the top, getting about 250 ml out that way (fill is 300 ml). Then filled with same amount of Chevron Dexron III ATF. Bottle perhaps 15 years old but never opened. Checked fill level to ring. Took the boat out Thusday and noted a surprising increase in vibration at all rpms. I am not talking about major shaking here, but noticeably different than before the oil change. Ran about 5-6 hours, no improvement. You would have thought I put water in there instead of ATF. Anyone got a clue on this or have I likely got something else going on?
