VHF radio with wireless WHAM Mic
544
None None Rochester, NY
Interesting Mike... In amateur radio this is caused because of the threshold set on the WHAM wireless transmitter. In other words, when a signal breaks squelch, it should then be transmitted to the WHAM. On my set, I can hear the first syllable on the base speaker, then I hear all but that first syllable on the WHAM. I have contacted Uniden a couple times about this, and they did not deny the problem, nor offer a solution, such as an adjustment in the WHAM transmitter.
Like I said, I have learned to live with it. I tell my radio buddies to count to 1 between PTT and speaking, and that works. I also turn up the volume of the base station so that I can hear the first syllable from below.
Dec 3, 2003
544
Just a thought.
Could it be that I just have my squelch set too high? Doubt it, but will play with that this coming season.
Mike B
Apr 15, 2007
1,013
Beneteau 43 Baltimore, MD
Ken, having had it for 7 years I can tell you it worked the same as the base unit. No syllables omitted or other issues with transmitting or receiving. I kept the squelch on the base unit set just a tad past where you would normally leave it. Turn it up until you cut the garbage, then just a tad more.
Mike
