David
I have a new 356 with an inverter and 2 shore power connections (main line and 2nd line for air conditioning/heat). When BOTH lines are plugged in and turned on there is a loud humming in the VHF radio and a lot of interference when I try to transmit. The radio works fine when out sailing and when the 2nd line is unplugged. The dealer says they have had this reported to them by other owners and it's the inverter/charger and nothing to worry about. Has anyone else noticed the same problem and is the dealer correct?
