Pit Bull Mentality
Larry, Et Al, In every community, there will be those that find communication particularly troublesome. As Larry has demonstrated, the easiest method to overcome this handicap is to use boorish and antagonistic language. The individual asking the original question probably has little experience in a boat of any size and is simply trying to understand the benefits of a piece of equipment before spending money on one. A VHF radio, although not required by any official agency, is considered to be a necessary piece of safety equipment on a modern pleasure craft. The use of one is easily understood after reviewing the operations manual and some of the readily available material provided by the Coast Guard or Auxiliary. The fact that most every boat is equipped with one makes it valuable in that a rapid response is more forthcoming than with a discrete communication over a device of questionable dependability, considering the coverage area of cellular towers in your area. If you, John, are a novice, you might want to consult with the other operators in your area to find out what the predominate models are. Considering that this will probably be an initial installation, you might want to enlist the assistance of some of your dockmates regarding installation, also. I would personally recommend that you consider a DSC capable radio. When you become familiar with the more routine attributes of the radio, the digital calling characteristics will be a welcome bonus. Additionally, the safety feature of the immediately available digital call for help (with the ability to be connected to an NMEA output from a GPS that will add your location to the individualized distress call) adds to the overall desirability of the DSC option. Larry, you don't need to be demeaning to other listers who ask a novice question. If someone had been as rude to you when you asked your first questions, meeting you on a port/starboard crossing wouldn't be a consideration, because you probably would not have figured out how to get away from the dock. Oh, and Larry, if "individual" is a "ten dollar word" for you, you might want to consider vocabulary lessons.
