Checking your antenna
Back to your original question. Borrow or buy a VSWR meter for VHF. You can ask most hams about where to locally get one. Place the meter in-line with your coaxial cable to the antenna. Key the radio, using low power mode, and read the VSWR. If it is more than 3:1, you have a problem with the antenna, connectors, or coax to the antenna.Many VHF antennas will appear to be electrically shorted if measured with an ohm meter, so be aware of that if you get to that stage of troubleshooting.You can check the connectors and coax by going up the mast and placing a 50 ohm dummy load at the end of the coax. Measure the VSWR, and you should get 1:1.For further troubleshooting hints, there are many books available to buy or at your library. Think of your marine radio as similar to an amateur radio 2-meter radio in your search for books. This is not the same as CB.Good luck.Ken Palmer, S/V Liberty
