i just pulled new wire and coax up my mast. when i did the coax and disconnected the VHF mounting bracket i noticed that the ground for the VHF is not only grounded to the radio through the coax as it should be, but because the VHF antenna mounting bracket is stainless, and the screws that screw the bracket to the mast are stainless, the antenna/VHF are technically grounded to the mast also...which is of course grounded to my iron keel. (hunter 23' bolt on keel). now while water isn't much of a "Ground" and salt water is little better but still not a real ground, there is some conductivity. i wonder if this has any effect on the ground and or performance of my VHF. i could possibly remedy this with either nylon bolts through the VHF mount or possibly plastic, (or other non-conductive), mounting bracket. i backed it with rubber gasket material. tia~william
