If you turn it on on 16 you should get a static blast when turning the squelch knob. Make sure you are getting at least 11 volts at the radio or at least on the radio side of the in line fuse. You should hear something on WX channels too. If not , try a emergency antenna or the coat hanger trick above but do not transmit , you will blow the finals. Also try the handheld and see if you can hear it on the new base station.
Pix of VHF and you get WX with button on right below the display.
