Vhf cable
mm2347
Oct 21, 2008
243
oday 222 niagara
I want to replace the Vhf cable on my S2 8m as it is starting to get brittle and has small cracks in a few places. It is about 1/4" in size and has performed well. Space is limited so I would like to stay w/ the 1/4 size. I believe LMR-240 cable can be used (about 50 ft length) with a nominal loss. What connectors will fit that size cable?
It is not the cable, you need to have the connectors fit the radio and antenna connections.
Feb 27, 2004
155
SunTracker 18 DLX PartyBarge Hoover Reservoir - Columbus OH
LMR-240 is the same size as RG-8X. So any connector sized for that and compatible with your current setup should work.
7,730
Alden 50 Sarasota, Florida
Any place which sells good quality coax will also stock the reducer you need to fit the cable to a standard PL259 connector
