couple of cautions
The std response to these questions is an SWR meter and multimeter. unfortunately, they both can be misleading. For example, if you hook up water-laden coax to a regular light bulb, you'd get the expected results for low SWR and a open feedline conductivity - and nobody outside of 100 yards is going to hear you. Similarly, your antenna could fall off the boat but still test okay depending on the electrical length of the coax connected to the radio.That's not to say either instrument doesn't have some utility - just that they don't necessarily confirm everything is fine.Start with them and if the feedline tests satisfactorily, check the output power of the radio (at the antenna end, not at the radio).Also check for proper voltage under load (when transmitting). It could also be low deviation of the radio (analogous to low volume on an am radio) although you'll not likley have the equipment to test that but it's not expensive to have it done. Usually, by the time you try any/all of these, the problem becomes apparent.Don
