Recently I noticed that the AM/FM Radio lit up and the speakers made a noise whenever I pressed the send button on the VHF Mic, even though the radio was turned off , including at the fuse switch.
As disconnecting the FM aerial from the splitter stopped this problem, I replaced the splitter. The problem appeared solved. However, 1 week later I am having the same problem.
Also, when transmitting with the FM radio on, the sound of the latter is severely disrupted.
Do splitters breakdown and, could this problem damage any of the radios?
I do not really want to connect the FM to another aerial, as I think I need the mast height for reasonable reception in our area.
