Verifying Alternator output!
I have the same basic setup in our boat, plus a Link 10 monitor. Based on your description, you have the all information that you need to determine if alternator is functioning. Your alternator will not advance beyond bulk charge stage unless there is a change in battery charge state. The fact that your alternator advances to a float stage indicates to me that there is a positive change in battery charge state. That can only occur in the presence of alternator output in excess of the circuit load. If you need to know exactly how much current is being generated you will have to measure output with a suitable ammeter. An ammeter that will accurately measure currents in excess of 10 amps usually requires the installation of a shunt similar to the one provided with the Link 10 monitor. You can hardwire a high current ammeter w/shunt, or better yet, install a Link 10 or Link 20 monitor. At the risk of overstating the obvious, did you remember to increase the alternator output cable to handle the increased output? Very important!Jons/v Beneteau 321
