venture cat 15
1
venture venture 15 catamaran minnesota
i recently purchased a venture cat 15 that needs the "coupling" (is this called a gooseneck?) that attaches the boom to the mast. the part i have is broken and appears it was juryrigged from the original part. two questions:
1) how is this attachment supposed to bbe done? any photos?
2) any possibility of a spare part?
May 29, 2009
98
Lancer 27ps Suisun City
Gooseneck
I believe it is called a gooseneck. The easiest way to buy replacement parts is to determine who made your mast, either from a tag on the mast or boom or from manufacturers literature. You can then measure the mast and discover which section it is. Parts can be obtained from the manufacturers website. www.rigrite.com is a place to start, some others are Ballengers Spars, US Spars, or just do a search for "spars". The most difficult way is to measure the old part and use the dimensions eg pin hole sizes, length, width, height, material, that plus a picture sent to Ballengers or Rig Rite should work. I'm sure that the rigging shop at your local boat yard could help you out as well, but that's pricey too.
Good luck
Rich
Jul 29, 2010
1,392
Macgregor 76 V-25 #928 Lake Mead, Nevada
Contact Bluewater Yachts in Seattle, Wa. They are the MacGregor parts house. If they don't have it they can tell you where to get it. Phone 1-800-688-8626 Tues - Sat 10-4. Y
Jul 20, 2010
81
Precision P28 Lake Ouachita
I second Rigrite. The original Venture spars were built by Kenyon I think and I believe Rigrite owns the original designs. Some goosenecks are attached directly to the mast with rivets or screws. On my old V17 the gooseneck was permanently attached to the boom and had a sail slide attached to it so that it loaded into the mast the same way as the mainsail. There was a downhaul attached to it to keep it below the gate but I always used a track locking slug above the gooseneck and below the gate just in case.
Jul 25, 2009
270
Catalina 1989 C30 Mk II Herrington Harbour South, MD
The folks are rig-rite are generally about as helpful as a sackful of wet kittens, so make sure you know exactly what you want when you order it. They are miserable with telephone and email correspondence unless you have a part number in hand and are talking to the sales department.
