Ozone
any opinions on ozone generators?
A one-time ozone treatment by a professional can be the best way to deal with a boat that's so saturated with mold that it would be impractical, if not impossible, to get rid of it any other way. However...
Ongoing use of ozone generators on a boat is a BAD idea for several reasons:
[FONT="]According to the EPA, “Available scientific evidence shows that, at concentrations that do not exceed public health standards, ozone is generally ineffective in controlling indoor air pollution. The concentration of ozone would have to greatly exceed health standards to be effective in removing most indoor air contaminants. In the process of reacting with chemicals indoors, ozone can produce other chemicals that can be irritating and corrosive.”[/FONT]
[FONT="] [/FONT]
[FONT="]As for how well the portable ozone generators work when it comes to getting rid of odors… yes, people who’ve bought them rave do about how well they work. And, yes, the manufacturers do assure you that the ozone concentration is well below that which can present any health hazard. But if that's true, they can't deliver enough ozone to destroy the sources of any odors. If they did deliver enough ozone to destroy the sources of odors molds, etc., it should only be necessary to run one occasionally. But among all the people you know who’ve bought ozone generators, have you ever met anyone who has one who's ever been able to turn if off without having odors return? That
should be enough to tell you that ozone generators are only very expensive air fresheners, because they don't deliver enough ozone to be anything else. Save your money and get rid of the SOURCES of your odors. Eliminating the source is the
only thing that really works.
[/FONT]
So by all means, have a professional ozone "treatment" to get of mold, mildew etc...but then you need to prevent new mold.
[FONT="]Fresh air and sunlight are the most effective enemies of molds and mildew, but there isn’t much of either one in a closed up cabin. So you want to allow the air that is available to circulate in every nook and cranny. When closing up the boat, leave lockers and drawers slightly open to allow air to get into them. Installing solar or 12 volt vent fans that pull air through the boat will help a lot. On the first warm sunny day In the spring, put all your soft goods—cushions, mattresses, rugs etc—along with life jackets and foul weather gear outside on the deck for the day. While they’re out, clean the hard surfaces and wipe with a mild solution of bleach and water or white vinegar and water. Just don't combine bleach and vinegar...that'll produce a gas that's even more lethal than that created by combining bleach and ammonia! [/FONT]
