We are doing a final install on a new head system and have hit one area where we can't make a final decision due to competing suggestions, so we hope the resident expert can weigh in. First, , the head bowl and top of the holding tank are above the static waterline, but both could be below the waterline when the boat is on starboard tack. Water supply for the head will be from a small, dedicated fresh water tank located under the (this eliminates at least on vented loop). We went with a very simple system where the head (PHII) discharge runs about four feet horizontally to the top of the holding tank, with a slight rise mid-way to prevent any backflow from the line into the head. Another line runs vertically from the bottom of the holding tank to the deck pump out. For emptying the tank at sea, we were going to install a 3-way valve on the vertical hose to the pump out fitting. That valve could be installed above the static waterline, but would have the potential to be below the waterline during extreme healing situations on starboard tack. From the 3-way valve, a discharge hose would descend to the overboard discharge thru-hull, with a Whale or similar manual pump somewhere in that line. The question is with this set-up, could we forego a vented loop on the discharge line to the thru-hull? The reasoning being that (a) the line between the thru-hull and holding tank would rise above the static waterline (with the 3-way valve always being above the waterline when pumping out at sea), and (b) the thru-hull would only be open when actively pumping out the tank when offshore. Looking for thoughts on this particular set-up . . .
