Vented Loop on Head Intake Line
Steve
Peggie, I was reading a thread on vented loops and noticed one installation that had a vented loop on the intake line and the discharge hose. Doesn't a vented loop on the head intake hose suck air when you flush? Thanks.
Dec 2, 1997
9,011
- - LIttle Rock
Not if it's the right place...
It will suck air if it's in the line between the thru-hull and the pump...it has to go between the pump and the bowl--to replace the short piece of hose the mfr uses to connect 'em. The toilet PULLS air to the pump...PUSHES it to the bowl...the loop won't interfere with anything pushed through a line.
