Vent Line greater than 45 degrees
2
Pearson 28 Rockland ME
I'm allowing for two large vent lines on a new tank (replacing bladder). The problem is that there's no way to route the vent hose without a steep slope greater than 45 degrees and the end of the run being almost vertical (90 degrees). The length is also about 5 feet which may be too long. Does this mean cross ventilation isn't going to happen.
Only one vent currently and if there's no advantage I don't want to run the second.
I searched but didn't find the answer. However, I am brand new to this forum and perhaps I just need a pointer to an existing answer.
thanks
Dec 2, 1997
9,011
- - LIttle Rock
No way? I'll bet there is...
If that's only due to the location of the current vent thru-hull, the solution is simple: install a new thru-hull.
A 5' long vent line is pushing it, but it's still barely within the limit for a 1" diameter vent line.
Where in the boat is the tank going? Where's the head located? Where's the current vent thru-hull?
Jan 10, 2012
2
The tank is going in the port side V-berth. The Head is located aft of the v-berth on the other side of the bulkhead between them. The vent line runs from under the v-berth at a low angle through the bulkhead and then straight up on the other side to a thru-hull just below the rub rail. That vent is 24 to 30" higher than the top of the holding tank (I'll have to measure to be sure).
To get a 24" to 30" rise at 45 degrees would take 34" to 43" inches laterally. I might be able to move the thru-hull about 33" aft and perhaps I can gain some by bring the vent hose closer to the underside of the v-berth. I'll have to go measure carefully. But thanks for the nudge.
The new 2nd vent line I was thinking of running to the bow area. But I can't do that at 45 without going up the side of the v-berth in plain sight and interfering with the occupant space. Now perhaps that is what to do and I have to "suck up and deal". But I was trying to keep the vent line "behind the scenes" by coming up in the anchor bow locker.
Dec 2, 1997
9,011
- - LIttle Rock
Your plan for the 2nd vent is the best one...
If we can do it right, you should only need one and it shouldn't have to be in plain sight...and I THINK the key to that is the location of the vent fitting on the tank. If you'd like to brainstorm this, shoot me an email.
