I'm allowing for two large vent lines on a new tank (replacing bladder). The problem is that there's no way to route the vent hose without a steep slope greater than 45 degrees and the end of the run being almost vertical (90 degrees). The length is also about 5 feet which may be too long. Does this mean cross ventilation isn't going to happen.
Only one vent currently and if there's no advantage I don't want to run the second.
I searched but didn't find the answer. However, I am brand new to this forum and perhaps I just need a pointer to an existing answer.
thanks
thanks
