Veers to port
Dec 7, 2018
256
C&C 27 Mk V Vancouver
if I let go of tiller while motoring. Fin keel transom hung rudder. Inboard two blade.
Culprit?
5,274
1. Shaft alignment
2. Rudder alignment
3. If outboard, motor is not on centerline
4. If outboard is on aft quarter, motor is turned slightly
5. It could be designed that way
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
Typical prop walk I would think.
If you are in reverse, prop walk takes the stern to port. In forward, the prop at low speed will take the stern to starboard (hence the bow to port) until you get good water flow over the rudder.
May 24, 2004
7,228
CC 30 South Florida
A little pressure under power is normal. What is not normal is a hard pull and mostly indicative of a fouled propeller.
